Code:
Vehicle: 2006 Toyota Yaris (1.5L)
Klms: 70000km
Oil: Valvoline Pro Blend (Workshop Oil)
Grade: 10w-30
Klms on Oil: 10000 (approx.)
calcium 1819
water
oxidation 12
lead 2
molybdenum 6
barium 0
fuel dilution 5.2
vanadium 0
silicon 20
chromium 0
silver 0
cadmium 0
zinc 751
tin 1
sodium 193
TBN 2.65
FTIR soot
aluminium 3
nickel 0
titanium 0
potassium 3
Viscosity@100 9.8
boron 5
magnesium 8
nitration 12
copper 0
iron 8
antimony 0
phosphorus 644
Laboratory Comments:
Dean,
Check for source of FUEL LEAK. Fuel is at a SIGNIFICANT LEVEL. Fuel dilution may be caused by component faults related
to injectors, ignition/timing or excessive blow-by. Additional causes include heavy throttle application, engine lugging,
frequent short trips, and excessive idling. LUBRICANT and FILTER CHANGE is suggested if not done at sampling time.
Base Number is MODERATELY LOW. Sodium is at a MODERATE LEVEL; Sodium sources: coolant (antifreeze), lube
additive or supplement, and/or environmental contaminant; Silicon is at a MINOR LEVEL; SILICON sources can be
abrasives (dirt, Alumina Silica), seals and gasket material, lube additive or lube supplement, and/or environmental
contaminant. Resample at half interval.
Oil analysis performed by Roktex.
Klms: 70000km
Grade: 10w-30
calcium 1819
water
oxidation 12
lead 2
molybdenum 6
barium 0
fuel dilution 5.2
vanadium 0
silicon 20
chromium 0
silver 0
cadmium 0
zinc 751
tin 1
sodium 193
TBN 2.65
FTIR soot
aluminium 3
nickel 0
titanium 0
potassium 3
Viscosity@100 9.8
boron 5
magnesium 8
nitration 12
copper 0
iron 8
antimony 0
phosphorus 644
Dean,
