Originally Posted By: BusyLittleShop
Shannow...
Whether you run a 30 or a 50 it won't protect the bearings
unless the oil is flowing and the more oil flow the
better protection
You have entirely no grasp on hydrodynamic lubrication.
The relative movement of the shaft in the bearings creates the oil film, which keeps the bearings separated, not the "flow" of oil.
The point at which the shaft and bearings are closest is the Minimum Oil Film Thickness in the bearing.
Things that affect MOFT (all other parameters being equal)
* More bearing diameter, greater MOFT.
* More bearing length, greater MOFT.
* Tighter clearance, greater MOFT.
* More revs, greater MOFT.
* Higher Viscosity, greater MOFT.
So...the Suzuki engineers designed the engine and made a recommendation on the oil to use...
Reducing the viscosity REDUCES the MOFT...plain and simple physics.
Can't get away from it, can't deny it, and flow doesn't lubricate.
Shannow...
better protection
