Originally Posted By: turtlevette
Originally Posted By: Oil Changer
Wrong. I seen it when we took the sample.
Seen what, ground up bits of gasket?
You are reaching just a bit aren't you?
I believe that it could be a 50/50 chance between the
MaxLife ATF being defective, a manufacturing defect in the
transmission itself or a combination of both.
My personal viewpoint is that the MaxLife ATF may have been slightly out of spec and the transmission had components that were slight out of tolerance the two faults combined added up to a serious failure.
