Hey guys,
I just bought a 2012 Toyota Highlander with the 3.5L and 26K miles. It is the first vehicle I've owned that specs 0W20 and 10K mile intervals. I've got a couple of freebies coming from the dealership and they use 0W20. However, I'm wondering about what to use down the road.
To that end, I'm curious if anyone out there has tested both a 0W20 and 0W30 in the same engine. If it is a Toyota engine, so much the better. I just want to use what is best, regardless of MPG/CAFE regulations, etc. I'm not sure I necessarily believe that is why 20 weight oils are spec'd, but it is always talked about...so it definitely puts doubt in one's mind as to whether or not 20 weights are truly the best for engine life.
So...2012 Toyota 3.5L: 0W20 or 0W30?
Thanks in advance!
Thanks in advance!
