I work at an oilfield port (Port Fourchon, Louisiana), its 24/7, 365 days a year rain or shine, im a mechanics helper, our facility is only 1.25 miles from the Gulf so you can imagine the hard life our equipment (trucks and forklifts) goes through. Things are constantly breaking down due to constant use and the work environment. I think it would classify as severe service. The truck in question is a 2010 Chevy 2500 Chevy 6.0 Vortec, 263k miles, all crew change highway miles, now its just a yard truck, it mostly idles around all day the most it travels is 3 miles around the port. It had a bad wheel bearing/hub assembly, i had never changed one before, figured it out and went ahead and changed it, torqued the bolts to spec, (hub bolts 133 ft lbs, brake caliper bracket 221 ft lbs) it works fine now but after i changed it i thought that maybe i should have put some blue loctite on the bolts. Should this be any cause for concern of the bolts backing out? The roads this truck travels is fairly rough, but then again it doesnt travel far distances, I would just hate for the bolts to back out and someone get hurt.
