I just got an oil analysis on my 2004 GMC Sierra 1500 5.3 with 140k miles. I replaced my thermostats 8k miles ago because my truck overheated (got to ~240 degrees for about a minute) when the thermostat failed. Over the last 8k miles ive had to constantly add a little coolant. I was hoping the system just had bubbles in it so i kept topping it off. Ive used about half a gallon of coolant over the past 8k miles.
Well today i got my oil analysis back with very high levels of sodium and potassium. Up until the thermostat failed i hadnt touched my coolant in 132k miles. I did some research and found that GM had issues with Castech heads that would develop small cracks in the oil return ports in the head causing a very small coolant loss into the oil.
Code:
OIL 5W-30
MILES IN USE 3.2K
MILES 140K
METALS
IRON 16
CHROMIUM 1
LEAD 11
COPPER 9
TIN 2
ALUMINUM 5
NICKEL 0
SILVER 0
TITANIUM 0
VANADIUM 0
CONTAMINANTS
SILICON 4
SODIUM 721
POTASSIUM 520
My wear metals all look good. My oil isnt milky at all. If i keep frequent oil changes and as long as my wear metals dont go up do i need to worry about my engine grenading until i can fix this cracked head issue?
Code:
OIL 5W-30
MILES IN USE 3.2K
MILES 140K
METALS
IRON 16
CHROMIUM 1
LEAD 11
COPPER 9
TIN 2
ALUMINUM 5
NICKEL 0
SILVER 0
TITANIUM 0
VANADIUM 0
CONTAMINANTS
SILICON 4
SODIUM 721
POTASSIUM 520
