i have a frankinstine outboard motor, its got the gcv 160 on it.
since boat motors are always under load, should i run 15w40 in the case instead of the 530 or 1030 ? this motor was a pressure washer engine in its original life. not sure if that makes much difference.
if i let the motor sit and idle ( 15 minutes ) the case is still isnt hot hot like my 190 pressure washer (operating as intended)
what do you think ?
what do you think ?
