Car is a 2002 Ford Falcon. ODO 324683kms at time of testing. It is run on LPG/CNG for most of the oil drain interval. 15000kms on oil.
Any ideas as to the soot reading being 6.6?
Code:
Water 0
Oxidation 13
Lead 2
Calcium 2700
Nickel 2
Iron 4
Copper 3
Sodium 3
Molybdenum 10
Boron 0
Nitration 10
Fuel Dilution 0
Chromium 0
Zinc 1016
TBN 9.9
Phosphorus 0
Silicon 16
Aluminium 8
FTIR soot 6.6
Viscosity @ 100 19.9
Magnesium 12
Tin 3
Laboratory comments:
Viscosity @ 40 is at 147cst, please check oil grade. Wear and contamination within acceptable levels. Continue to monitor.
Code:
Water 0
Oxidation 13
Lead 2
Calcium 2700
Nickel 2
Iron 4
Copper 3
Sodium 3
Molybdenum 10
Boron 0
Nitration 10
Fuel Dilution 0
Chromium 0
Zinc 1016
TBN 9.9
Phosphorus 0
Silicon 16
Aluminium 8
FTIR soot 6.6
Magnesium 12
Tin 3
