Originally Posted By: Pop_Rivit
I'm just curious-is there a reason why you can't correct the issues with the kitchen ventilation? A decent vent hood combined with proper exhaust shouldn't be difficult to install, and you won't have to go outside every time you want to really cook.
This is at our rental apt. These units have not been designed to vent to the outside. Any modifications are out of the question.
Ah-I understand. Thanks.
Originally Posted By: IndyIan
I'm sure lots of kitchens don't have the stove on an outside wall, which might make retro fitting a big job...
An inside wall, unless it's a vaulted kitchen ceiling, would make it even easier to retrofit. Just run the duct straight up into the attic and through the roof. On an inside wall you've most likely got plenty of room to work in the attic, as opposed to an outside wall where you may be trying to work in an acute attic corner.
