Hi badtlc,
Any update on this issue? I have a Wix 49247 in the queue for my Mazda 6 - I took a good look at it and did notice some very minor damage to the gasket - IIRC, what appear to be one or two 1 mm deep and 3-4 mm wide chunks missing from the outside of the gasket - but in my subjective opinion this would not result in any air leakage because the gasket compresses when installed, so this whole portion would lay flat against the filter box so the chunks would not be exposed.
Mine definitely did not look nearly as bad as yours, though. I agree with you, I wouldn't run the filter you pictured and it makes me think I'll probably grab an OEM filter and use that instead of the Wix.
I'd be interested in seeing pictures of your second Wix 49247, the Fram CA11259, and the Mazda OEM filter.
On a somewhat related note - I recently installed a Wix cabin filter (#24103) in my Mazda 6. It did not appear to be quite as good as the Mazda OEM filter (Wix had 30 pleats, Mazda had around 38-39 pleats). The Wix was $21.99. If the OEM Mazda can be had for under $30, I think I'll go that way next time.
