Since engines are liquid cooled and have a set operating temperature why does the upper ambient temperature matter when selecting an oil grade? I totally get the low ambient temp being important because the oil has to be able to flow at startup in a cold engine but the engine gets to 200+ degrees at operating temp. Why for example on one chart will they say a 5w30 good to 104 degrees and a 5w40 is good to 122 degrees?
Where I live I have seen up to 117 so it is relevant to me but I just can't grasp what difference it would make because the engine gets so much hotter than the air temp and it stays constant for the most part. My engine reads around 205 degrees regardless if it is snowing outside or the middle of summer.
