OVERKILL
$100 Site Donor 2021
MMO isn't really intended to be a "flush" it is more of a slow, steady cleaner. Use a more modest amount in the future and simply run your normal OCI if you intend to clean it up with MMO. The PYB is an excellent choice for the oil.
You can run what you have much longer but it sounds like you've already got "the itch".
Question for you: If the solvent flashes off, how can it be a slow, steady cleaner if all you are left with is the base oil/carrier?
We don't know ALL the cleaners flash off, we just suspect they might. MMO says to run it full OCI, they ought to have an idea.
MMO is not promoted as a "flush".
I have used it and had a drop in level requiring top off, and I have used it where the level hasn't budged at all.
May depend on application then
An engine with a sump that doesn't get overly hot may benefit (possibly) from the solvent not immediately disappearing the first time it gets to operating temp then eh?
