2010 Pontiac Vibe 1.8 base, auto trans.
My wife noticed several lights on her dash today: "VSC Off" is flashing, and the ABS, Traction Control, and Brake lights are on steadily. The brakes work as usual, but there's no anti-lock.
Online searching brings up a lot of hits about bad rear wheel sensors and corroded connectors. The sensors are integral to the hubs and apparently expensive to replace, and I can't shadetree them right now.
Here's what I've done:
1) Checked codes with Torque. None are stored, but I don't think Torque reads ABS codes.
2) Checked for leaking brake lines and damaged ABS wires and connectors. OK as far as I could tell outside at night in the cold. The master cylinder is full and the pedal feels normal.
3) Disconnected the battery. Lights came back on when I restarted.
I'm going to clean the rear connectors this week when I can, depending on work and weather. Any other suggestions? Thanks in advance.
