I think we're missing some info from you.
What is the amperage draw with the radio hooked up? What about with the radio on?
When you were listening to the radio after you hooked it up, did you have the key in the "ON" position or the "ACCY" position? If you were listening to the radio with the key in "ON" and the battery is the original, it very well could have drained it in 5-10 minutes and still restarted the truck after charging- then appear normal.
I'd be surprised that there is a problem with the new radio and if there is, you should be able to figure it out pretty easily. Most have spindly little power and memory wires. If it's drawing enough to drain a battery in 5-10 minutes, they are going to be HOT, or the fuse (which is typically less than 5 amps) will blow.
