Originally Posted By: Radiation_Joe
Originally Posted By: CT8
What is the mix supposed to do over a regular off the shelf Redline oil?
In this case, I'm trying to get the viscosity down a little. The 5W-20 street oil Vis @ 40°C cSt is 53. The mix theoretically brings this value down into the mid 40s.
I've run the exact same RL blend in the past when the HTHSV of their 5W-20 was a whopping 3.3cP. The mix had an operational viscosity based on oil pressure not much lighter than a 5W-30 like M1.
The current RL 5W-20 is lighter with a 3.0cP HTHSV which really is that of a light 30 grade so this mix is going to give you an operational viscosity of a heavy 5W-20, perhaps something a bit heavier than Amsoil 5W-20.
RL and particularly their race oils have a low pressure-viscosity coefficient, meaning their KV spec's are lower than what you'd expect compared to most other oils. So dispite it's low 5.8cSt KV spec' it's HTHSV is that of a typical 0W/5W-20 grade but with a very low VI.
By comparison TGMO 0W-20 would be considerably lighter on start-up than even running RL 10W straight.
