I'll pick up where I left off on the "all fluids changeout" project on the old Dakota. Last Fall I changed out clutch, brake, xfer case and P/S fluid (and engine oil of course). Next is both diffs, manual gearbox, and coolant.
I'll also continue the Dakota "change out all non-tire rubber" project. I just changed out all 4 bump stops and the front brake hoses. I have the rear brake hose, and I ordered the radiator, P/S and heater hose pairs, they are coming in soon. I'll combine the coolant changeout with the new hoses. I still need to assess the vacuum and emissions lines, but I'll get to that soon.
"Changed out" doesn't exactly describe removing the old bump stops. One rear stop rubber was missing entirely. The other came off in my hand with a tug, and one of the fronts I removed with my fingertips, bit by bit.
Yes, bad planning on the P/S fluid, this is what happened. I went to remove a hose to flush it, and it broke off. From above it looked fine, from below it was surface cracked like an ancient desert dry lake bed. At that point there wasn't much to do except finish the flush, put it back together carefully, and plan for the hose change. It was then that I decided an all-around rubber replacement was in order.
Rushing off to AAP was not an option because I don't like their Chinese hoses. This is not my daily driver, and it's not Fall hunting season, so I decided it could wait until Spring for new US made hoses purchased with good discounts.
Come Summer-time and good hot dry day, I plan to do the Kellsport FluidFilm NAS thing on it.
