Originally Posted By: DoubleWasp
1. If your engine runs at the thermostat's rated temp, this will not help you.
2. If your engine overheats, fix the problem. The exception here, is if you have a vehicle (vintage etc.) where it had overheating problems from the factory, and changing or modifying components is not reasonable. Here, this product (if it works) will help.
3. If your fans come on well, well after the thermostat's rated temp (I'm looking at you, GM), reprogram your fans to come on sooner.
1: my temperature gauge would beg to differ
2: it doesn't overheat, has immaculate maintenance and there is nothing to fix. Just things to make more efficient.
3: my fans function just fine.
Overheating is the fastest way to kill these magnum engines. This is just a supplement to keep the engine cooler. Nothing else to understand.
I have had plenty of Magnum engines myself. I understand that even when new, extreme heat could get the better of them. I remember during the car magazine's off road shootouts in the desert, magnum engined trucks of any cylinder count fell prey to overheating. This is what lead to the Grand Cherokee with Magnum engines getting the hydraulic cooling fan.
But for overheat protection, I think a better radiator would do more for you.
As for now, the radiator is beautiful. No corrosion, flush came out clear, OEM fluid was changed well before it was time and more OEM fluid in a 50/50 concentration was added. This purple ice was just a supplement to run cooler, not doc anything. Having said that, I will keep this vehicle forever, so when the time comes I will put a bigger/better radiator in it if need be. That time will be a long way off though. It is a 2006 Dodge Ram that JUST rolled over 90k miles this week
