gathermewool
Site Donor 2023
107k miles. I've had a rattle for the past 20k miles that has gotten worse, coming from the drive belt area on the passenger side of the engine. I thought it was due to the hydraulic mount being faulty, but that didn't fix the rattle (though it did fix the loud rumbling that occurred at first startup and over bumps or heavy braking - the mount was faulty.)
I replaced the drive belt when I swapped out the mount, because it was accessible, and like a bone head I forgot to check the tensioner. I did NOT notice any issues with the tensioner while compressing it to install the new belt, and the neither the new nor old belt squeals or has an issue with tension.
Now that the rumbling due to the mount is gone the rattle is much more prominent. The colder the startup temp, the louder the rattle. I bought a Lisle mechanics stethoscope to poke about with, and while the stethoscope can't be assembled completely, because the metal disc doesn't thread onto the metal rod, it worked well enough to hear a definite change in sound when I poked the tensioner, compared to the head, block, alternator bracket, hydraulic mount and bracket, etc.
With the sound now clear via the stethoscope, I could also see that the tensioner seemed to flex or move a small amount in time with the noise I heard. I know a good video would help, and I'll try to get one when I can, but I'm almost certain that the issue is the tensioner and not a heat shield (none rattle at all.)
TO THE QUESTION:
Online Majestic Honda Parts illustration number 17 has two part numbers for the bolt that fastens the tensioner to the block:
90001-R1A-A00 017 001 BOLT, SOCKET (10X59)
96700-10055-18 017 001 BOLT, SOCKET (10X55)
I contacted Majestic Honda and they said either would work. I mentioned that that doesn't make sense, but they insisted that even a VIN lookup showed both fasteners as being acceptable. The difference appears to be 4mm in length (~1/6")
Any ideas?
Also, with this exact bolt being a failure point in the 2006 Civic (causing massive damage or shearing off and having to be extracted while replacing it due to maintenance, IIRC) I'm thinking about letting someone else do this. Any suggestions?
TO THE QUESTION:
Any ideas?
