One thing that baffles me is that there seems to be no guidance on replacing the crankshaft damper, or "harmonic balancer" as some call it, when it comes to general auto and pickup engines. With heavy duty engines, there is some guidance that the damper needs to be replaced at certain intervals, as the silicone in the damper can harden and the damper can loose effectiveness at absorbing the torsional shock on the crankshaft when a cylinder fires. I extrapolate what I do with my auto and pickup engines regarding the damper from the general idea as it applies to heavy duty engines. For the latter, it is recommended that the damper be replaced at 500,000 miles, which would correspond to the average half life cycle of those engines. So, to that end, I view changing the damp on a auto or pickup engine would be a good idea at 100,000 miles. That is pure self selected. No data I can find that confirms that assumption. So I'll stick with it.
