Why no Kreen for regular additive?
South East Asia
As far as I know, Kreen is not recommended for long term additive like MMO or Auto-RX.
I am just wondering if there is any particular ingredient that cause problem in the long run ?
Not sure why kanolabs also never promote it for car maintenance openly like Auto-RX.
Kano is a huge supplier of industry. Their biz is aligned with institutional sales.
Retail to the public is not their mainstay...
Its a solvent I wouldn't want that in there. Might as well put gas in there.. unless there is a particular problem you are trying to solve it might create more issues than fixing.
IE piston soak ok, just running it in crankcase to do what? not ok.
If it DID partially dissolve some sludge running it in the engine oil... you might end up with a blockage somewhere which is worse.
