Originally Posted By: 4wheeldog
Originally Posted By: zray
No one else is mentioning this, so I'm jumping in with both feet.:
WHAT THE HECK !
Am I the only one that can count ? A1995 motor is not that old,it's barely 20 years old . I've been putting high quality synthetic oil in engines. 45 to 60 years old for the last 15 years. Don't let ANYONE tell you an older motor can't benefit froma high quality synthetic oil. Cast iron rings running up and down a cast iron cylinder or cylinder liner don't know if they are 50 years old or not. They only know it's gets hot doing their job, and synthetic oil reduces the friction they endure.
C'mon, have a heart. Give those old rings a break. They will last LONGER. The same goes double for rod and main bearings. And don't even get me started on flat tappet camshafts.. That means no roller lifters to you youngsters under 50.
So what if the engine uses a little oil. Put some synthetic oil in there anyway. You'll add more years of service to a engine on its last legs.
I've bee working in engines since 1963. I only wish synthetic ol was in widespread use back then.
Z.
I am even a bit older than you. And I use synthetic oil in almost ever motorized object I own.
I would agree with you (I have an engine that has 250k on it, synthetic all the way, never has used a drop).
Except......What do you consider "Using a little oil"? If one of these Saturn motors uses a quart every 700 miles on dino, it is likely to double that, on synthetic. Just sayin'.
Tell ya what, in the Interest of science and gambling, I''ll buy that Saturn owner a jug of Mobil 1 15w-50 if he will use it. I bet 4 quarts of the 5 are still in the crankcase 1000 miles later. If only 3 quarts are left , you win.
Now, what are we going to bet ? Has to be worth at least the price of the jug of Mobil 1 I'm putting up.
Z.
WHAT THE HECK !
Z.
Z.
