The same old girl again, 1997 Acura Integra with 252k miles, rebuild 3 months and 1500 miles ago.
History:
Head warp at 180k miles due to cooling issue, head resurfaced and gasket replaced. Ran fine till 250k miles and the radiator cap stuck closed, creating a vacuum in cooling system and warp the head again. Head resurfaced, new belts, new water pump installed.
Now:
The engine shakes worse over the span of a week and I found a bad "torque mount" like this. I replaced a leaking oil pan gasket, NTK upstream O2 sensor (it was white and looks like silicone poisoned due to the past 2 head gasket leak and has 100k miles on it), and cleaned the idle air control valve with non chlorinated brake cleaner.
Problem:
After resetting the ECU (disconnect battery for a few hours), the car would drive fine and idle fine on the road, actually runs very smooth as well just like a new car. BUT, it seems to have a cold start chatter the sound of piston slap at the first 1/2 second when I cold start the engine the first time. If I turn it off after 5 seconds and immediately start it again, it wouldn't have the cold start chatter. At warm start, once in a blue moon I would have some rough idle but no cold start chatter (idle dropped to about 500 and runs rough for a few seconds, revving it up to keep rpm higher for a few seconds seems to get rid of it), and finally yesterday, the rpm dropped so low in a warm idle that the engine "squeak" unless I rev it higher for a few seconds.
No coolant lost at all, both in the reservoir and the radiator.
What could it be? Could it be bad idle air control valve, coolant temp sensor (not sender as it seems to be warming up in the gauge fine), bad timing, timing belt skipped a teeth, or another head gasket?
History:
Now:
Problem:
