Originally Posted By: Johnny2Bad
Generally speaking, an Automotive OEM is going to use the minimum wire gauge, but there are certainly exceptions. The reason is copper is expensive, relatively, and copper is heavy, relatively. Keeping manufacturing cost down and keeping weight down are objectives of the OEM.
If an upgrade alternator was available as an option on the vehicle, the wire gauge *may* be adequate for the higher amperage charging system. Similarly, there may be economies of scale to use the same wire gauges across a platform.
What is needed is to assess the needs, and then assess what you have installed.
To assess the needs, determine the amperage rating of the upgraded alternator, multiply by a safety factor (+25% - Minimum Recommended, up to +100%); and then measure the total length of the circuit (eg from battery to connection point and back to battery, ground point, etc).
The length is quite important as you can use a surprisingly small gauge of wire for very short lengths and carry a large amount of current (which is the basis for automotive fusible links).
You then check a chart to determine the recommended wire gauge. Be sure the chart is for DC current, preferably 12V, and not AC. AC is only at 100% flow twice per cycle, DC is at 100% flow all the time; thus going by AC will result in under-sized recommendations.
You are looking for a maximum voltage drop of 10% for any automotive circuit and I would recommend less in a battery/charging circuit. Do the calculation and use what you are comfortable with. Consider alternator output of 14.4V less 10% = 13.0V available to charge your battery. Not enough.
Please note the following:
Automotive wire gauge is not equal to American Wire Gauge (AWG); the Automotive stuff is smaller / lighter (added weight of vehicle rears it head again), so either use the correct chart or go up one gauge for proper Automotive-rated wire vs AWG
I recommend you use proper Automotive-rated wire (meets SAE J-1127, covering battery and ground connections), and you have a choice of PVC-Jacketed (type SGT) or Cross-Linked Poly Jacket.
Battery-rated Automotive wire in Cross-Linked Poly (XLPE) Jacket rated for -40C to +40C /-40°F to 257°F. You have a choice of type SGX and STX, with the latter having the lighter jacket.
Many people use welding cable, which will be AWG but note the jacket is not as durable which can lead to high current shorts, which is A Bad Thing. If you go this way, route with good practice (proper strain relief, consider motion such as engine block under load, interference with other components, etc) and be careful not to nick the jacket in installation.
Use one of the following charts:
SAE Automotive Wire:
http://news.waytekwire.com/automotive-wire-gauge-guide/
AWG:
http://www.supercircuits.com/resources/tools/voltage-drop-calculator
Thank you...this is good information!
Ed
