I just called a local transmission shop to get a price for a full fluid exchange. Without saying it at first, all he does is drain the pan and refill with same amount. I asked if ever did full fluid exchanges and he said that isn't possible. He said Honda was the only one who had transmissions you could connect the input/output cooling lines and actually exchange all the fluid. He said for everything else, you can run as much fluid through the lines as you want but it won't replace anymore existing fluid with fresh fluid than if you drained/refill.
Has anyone ever heard this before? He said he was due to the design of the torque converter transmissions but I wasn't able to keep up with some of the technical details he was explaining.
He is definitely a no frills, no upsales kind of guy. He said anything but an OEM fluid was complete [censored]. We all know better than that but I can respect a guy who won't needlessly push the envelope.
