Greetings, all. So here is the first report I've gotten since a summer of 2013 head-gasket replacement on an older D15Z1. It looks better than before. However, I'm not sure if what is in this sample is just trace remains of coolant or not as this is the 3rd OCI since the job and the first UOA.
Also, this is the first time I've seen fuel worth noting in a sample to Blackstone Labs on this engine.
Length of OCI is 7 months, with 1.5 Qts added during the interval.
Oil filter used: Bosch D+ 3312
Air filter used: aFe Pro Dry S (drop-in replacement) Best readings yet!
Code:
OIL MOBIL1 AFE 0w-30
MILES IN USE 5,500
MILES ON UNIT 287,500
SAMPLE TAKEN 02/10/15
Make Up Oil Added 1.5 qt
ALUMINUM 3
CHROMIUM 7
IRON 18
COPPER 8
LEAD 8
TIN 0
MOLYBDENUM 69
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 6
BORON 44
SILICON 9
SODIUM 37
CALCIUM 1373
MAGNESIUM 540
PHOSPHORUS 614
ZINC 744
BARIUM 0
SUS VIS 210ºF 56.2
cSt @ 100ºC 9.11
FLASHPOINT ºF 360
FUEL% 1.3%
ANTIFREEZE% ?
WATER% 0.0
INSOLUBLES% 0.3
TBN 2.4
http://i.imgur.com/AjzqiWu.jpg
Code:
MILES IN USE 5,500
ALUMINUM 3
CHROMIUM 7
IRON 18
COPPER 8
LEAD 8
TIN 0
MOLYBDENUM 69
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 6
BORON 44
SILICON 9
SODIUM 37
CALCIUM 1373
MAGNESIUM 540
PHOSPHORUS 614
ZINC 744
BARIUM 0
SUS VIS 210ºF 56.2
cSt @ 100ºC 9.11
FLASHPOINT ºF 360
FUEL% 1.3%
ANTIFREEZE% ?
WATER% 0.0
INSOLUBLES% 0.3
TBN 2.4
