I have a 2004 Toyota Tacoma and I want to clean my throttle body for maintenance reasons. I also want to clean the IAC valve, so I'll remove that from the TB prior to cleaning. I'm just trying to get the whole assemble squeaky clean!
I see the TB has some part (I"m not sure what the formal name of the part is - it kinda looks like a plastic choke cover) that's plastic.
I've looked at Berryman carb cleaner that comes in a gallon size, and I'm wondering if it's safe to disassemble the TB and IAC, remove any gaskets (of course) and then just soak the whole TB and IAC in the cleaner? Berryman says their cleaner is "plastic safe" (http://www.berrymanproducts.com/products...-parts-cleaner/) but I'm slightly skeptical. If it is safe to do so, how long do you think I should let it soak?
Comments? Suggestions?
Ed
Ed
