Originally Posted By: badtlc
Originally Posted By: inquirer
So what's the deal? I am asking because I already use one of these oils...
It is a better safe than sorry approach. Many GL-5 fluids have destroyed synchros. Some newer GL-5 fluids claim they are yellow metal synchro safe and they probably are. But a safe general recommendation would be to avoid them.
I think Molakule can recommend dual rated GL4/GL5 fluids that are safe for yellow metal synchros. Motul might have been one he recommended previously. I know Fuchs was one of them.
The thing is when a company like Motul (which undoubtedly is a huge reputable company) states explicitly that their GL-4/GL-5 oil is OK for synchronized gearboxes should it be trusted or not? What should I decide as a consumer?
For example for the Motylgear 75W80 which I use Motul states:
"Technosynthese® lubricant designed for all mechanical transmission, synchronised or not synchronised gearboxes, gearbox/differential and transfer gearboxes without limited slip system operating under shocks, heavy loads and low revolution speed or moderate loads and high revolution speed. "
Originally Posted By: supton
Originally Posted By: 29662
Redline MTL. I use Redline MT90 in my Toyota and I can say that it's very possibly the best gear oil I've ever used in a manual transmission.
I have MT90 in my Camry, and I need to wait for summer before I condemn it. But it's definately the wrong stuff for winter.
Is it the right grade? I did a quick search for a random Camry using Red Line's application guide and it recommends the MTL, not MT-90...
