so on my 1995 Lexus LS400 I noticed that there is a spot where the defroster isn't working.
I haven't had an issue with the rear defrost on any car before
there are two leads on the drivers side middle of the window, they look fine.
From what I can guess from the pic there must be some kind of break either on 3 of the lines or maybe just the 1 line in the center of the strip of snow.
I carefully looked inside and I don't see any obvious breaks in the line....? can I use a multimeter to test these?
For the expert out there does the power come from the sides or the middle?
(the snow looks to be melting from the middle out)
unless that is because when driving the snow is being blown up on the sides?
