Help!
My tractor is a New Holland Boomer 3050 Diesel.
The engine oil is Ambra Master Gold SAE10W30, I believe I have the 15W40 version.
The transmission oil is Ambra Multi G134 which is a 10w30 weight I believe.
I accidentally put 250ml of 10w30 Tractor Diesel Engine Oil into the Transmission which takes 40 Litres of Multi G transmission fluid.
Will the additives in the diesel ruin my tractor, do I need to drain and replace the transmission fluid by only putting a small amount in. I realised the viscosity was wrong as I was pouring it.
Picked up the wrong bottle.
Any help would be appreciated.
Dave
Dave
