We did the deed this afternoon and it took about 4 hours with my son doing most of the work (It's his truck after all!) We did the trick of leaving the steering column hooked up while pulling the dash back just far enough to get the core out. Overall, not as bad a job as I had feared.
The core sprang a leak last year due to some neglected coolant and resulting corrosion (trust me, get that antifreeze changed when you're supposed to!) He used some stop leak and that worked on the leak but unfortunately also plugged up the core so very little heat was coming out. He tried a mild flush to help the heat but that opened the leak back up again.
At any rate, all back together now with great heat! Working with dash boards is never fun, but I've had worse jobs!
