Jetta with approximately 94,000 miles leaks about 1 to 2 drops of motor oil.
Automatic transmission
The engine cover was removed and did not see any oil at the valve head cover.
No oil leak at oil pan drain bolt.
No oil between the oil pan and engine.
Have read about the vacuum pump being a culprit in most of these cases.
Anyone here have experience with oil leaks with these cars?
Please advise
Please advise
