Originally Posted By: kschachn
I was going to ask what Shannow just asked but he beat me to it.
On top of that question though, why is 20 degrees cooler a good idea? You want the engine to operate at the design temperature for greatest efficiency, don't you?
Originally Posted By: jk_636
Why does there always have to be a problem to solve?
They advertise that it can get your engine to run up to 20 degrees cooler. Sounds like a good idea to me!
This is exactly what I was questioning.
When discussing stock engines, why would we want to lower the operating temperature? Aren't engines designed to optimally operate at a specific temperature range? And don't the engine designers select the thermostat that keeps the engine running in that temperature range? If the designers wanted the engine to operate at a lower temperature, wouldn't they simply spec a lower temp thermostat?
It seems to make much more sense to use products, such as Water Wetter in a heavily modified or custom built engine, where it may be more difficult to get the engine to run at the correct temperature.
So, yea. Unless there is a problem, why would one want to lower the operating temperature? Am I missing something?
