I scratched my spark plugs' ground electrode using the gaping tool. The one with the wire. Are they safe to use? Will they cause hot spots and knock/detonation/pre-ignition? I sanded the outside of the ground electrode a little bit to remove the sharp edges from the scratches, but there are still scratches on the inside of the ground electrode.
Should I throw them away? Not really worth it all if they could damage my engine. Don't care if they're expensive iridium plugs. Any tool recommendations for gaping spark plugs, that won't scratch the ground electrode?
