A 750 watt computer power supply appears to have its T15A250v white ceramic fuse blown.
Although it will serve as back-up if/when repaired, the 5mm x 20mm does not indicate if it's a fast or slow blown fuse. This is a soldered to the board type. Not a snap in.
Does it matter what is selected?
