Originally Posted By: tr4petty
I'm curious as to why the manufacturer always says NOT to extend oil change intervals whether or not you use conventional or synthetic oil. I've read a lot of comments on here about the benefit of synthetic oils being extended OCIs. BUT, . . my owners manual specifically says to use 15W-40 conventional OR 5W-40 synthetic CJ4 oil, depending on the temperatures and also points out that the oil change intervals should remain the same whether using conventional or synthetic. Is it just CYA?
going by the claims made on the oil bottles will get you into trouble possibly.
1. Some syn oils claim 10k plus OCI is ok wiht their product, my 08 dmax is known to kill the oil with diesel contamination due to DPF cycle.
So extending the OCI without understanding your engine and sampling at proper interval might land you in trouble.
Then you are fighting a finger pointing game with the dealership.
OCI is cheap, 2 gallons of oil costs 20$, why take chances?
Don't forget UOA costs $$ too.
