Pulled a hub bearing off a friend's BMW with 115K miles on it and we were test spinning it to see if it was rough. It was pretty smooth, but we were surprised at how much drag a used bearing had and we pondered why. I surmise the bearing is built with interference or assembled with the balls loaded to keep any play out. If not that it is the grease type being intended for high temps and feels draggy at room temp. I doubt if used seals add that much drag.
