Often you see TV adds or tests on Youtube where someone puts a little oil on a bearing and places it in this machine with an electric motor and a bar that you put pressure on and see how long it takes to stop and then the person shows you the wear scar on the bearing and his special lube always has the smallest wear scar. I dont know what the proper name of this contraption is I like to call it a one arm bandit. I was wondering is this test even valid as far as what goes on inside an internal combustion engine? Does this test have any real advantage or meaning on what oil or additive someone decides to use?
