jeepman3071
Thread starter
This is a regular flooded battery.
My headlights are actually already on a relayed harness. That was one of the first upgrades I did when I bought it 5 years ago, since it is a common issue with Cherokees to have weak headlight wiring. I upgraded the ground cables as well when I did the cable upgrade. My main power, ground, and alternator cables are all upgraded.
Today I actually swapped out the 150A alternator for a used stock one from a local junkyard. The alternator turned out to be a Napa rebuild alternator from 2007 judging by the sticker on it. This seems to help a tad bit. I still get a big voltage drop with the high beams on at idle, or when the fan kicks on at idle, but it seems to be a little better than the other alternator.
I'm wondering if my battery just can't handle the load at idle, and maybe I need to get a deep cycle battery, which is what I had before (Optima).
