This trans is from a MB delivery truck for one of the major Deliver co. They were replacing the trans with this new rebuild when they dropped it(aluminum) and broke off this corner.
Originally Posted By: CT8
That is what is nice about weldable aluminum. I had an engine builder tell me aluminum engine blocks that are damaged can be repaired.
Yes they can.
I have repaired several small 4 cyl alum blocks that were damaged in wrecks. Some had large holes broken out into the water jacket.
Thanks. This is the second trans I repaired in the last three weeks. The other was for a Chevy truck. A rookie tightened the top two bolts on the bell housing when the alignment pins were not aliened with the housing. Broke the top of the bell housing off.
