I picked up a 2001 GMC 1500 last week for either a flip or keep. Truck has a 4.3L V6. Code shows random misfire, runs like [censored] at low rpms..wont hardly idle..runs great at 2500Rpm and above.
What I have done- New Distributor and cap. New Spider. New plugs. Swapped coil and wires from another great running 4.3 with no help. Also was told that the temperature sensor could be it so i replaced that with no help.
Compression Test- 135-140 psi on all 6 cylinders.
Tried to rule out cats by pulling o2 sensors..no help.
any ideas?
any ideas?
