Originally Posted By: thunderfog
Man, I don't know about those cartridge filters. Anyone have any experience trying to change those?
If you're the ONLY person who does oil changes on the vehicle, they actually aren't too bad. Toyota puts a little drain plug on the cap so you can drain out most of the oil held in the filter before removing the cap.
The problem is, people over tighten the Toyota caps all the time, probably by using claw pliers to tighten, or just tightening the cap as much as they can. Once they go through a few heat cycles like that, have fun getting the cap off. I have seen $100 Toyota-specific adapters break in half trying to remove an over tightened cap.
I wish they used a cartridge design that was more like the GM Ecotec and Chrysler Pentastar. They are up top and have hex heads on the cap. I have seen a couple mangled up Ecotec caps, but not nearly as many as with Toyotas.
