2000 Durango, 4.7. 124,000 miles. Had it for year and a half (14,000 miles).
Trying to diagnose what I'd call a weak shift. Not crisp, takes a half second longer to shift compared it its "best" shifts. It's more noticeable if I accelerate more slowly. For instance, the shift from first to second is crisp at 2000 or 2100 RPMs. If it shifts at 1700 RPMs, though, there's a bit of a lull. I'd call it a sluggish feeling. A hesitation.
I try and avoid it by accelerating faster than I otherwise might to let it shift at the slightly higher RPMs.
Fluid is good. Maintenance records from previous owner shows it's gotten fluid changed at various times. I serviced the ATF and installed new filters when I got it.
Shifted this way as long as I've had it...just trying to figure out why.
