Originally Posted By: SumpChump
Originally Posted By: KrisZ
What's wrong with draining the factory fill and putting in the exact same amount? Factory approved procedures are not the only way things can be done.
I was contemplating that. That would be awesome.
But... and here comes the "ugh!" part...... I've met several members unfortunately who did the measurement of what came out and then did the procedure for fill level and the tranny was under filled from factory.
It's the same story over on VW forum.
How do you know the tranny is under filled from the factory? If you are using the 25 cent plastic tube as a measuring tool, then it can be easily argued that the QC on that tube does not match the QC of the ATF filling equipment in the factory. So how do you know you are getting the correct length on that tube? And then the manufacturer can also change the tube length specification at any time and you would never know about it. Simply put, people put too much trust in that cheap plastic tube.
Another point is that if the level was incorrect from the factory, and the trannies were as sensitive to the ATF level as the interwebs make it out to be, don't you think we would see a bunch of issues with the trannies on the factory fill?
