Originally Posted By: Mud
Interesting discussion on this. I can offer only a lone perspective within the internet wilderness - I had paused to make some subjective observations on our 2008 V6 Accord:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3313612/1
Within that post:
"Related to comments about frequent (shorter) OCI's on VCM type of engines I totally agree. I've stuck with approx 4500 mi OCI's since new using whatever quality oil is on sale - PP to PYB to Havoline, etc. Filters were OEM,MC, or Wix. Doing the same on the 2011 Silverado. I've never had an issue with sludge or similar - I have one of those HF cameras that are on a flex head, looking inside the valve cover there's a bit of discoloration here and there, other than that everything is clean, nothing collected in corners and crevices. I don't use any oil additives, I will use some Techron in the tank whenever I feel like it and its on sale."
I did replace the PCV at around 75K I think it was and it was clean, still rattled. I thought about leaving it in, but with a new one in hand, I replaced it but kept the original. Interesting that the orifice sizing on it is quite small, I could see how clogging could happen.
The car uses about 1/2-3/4 qt of oil between changes which I've not worried about. With all this said, this is a snapshot of current condition. Always a possibility of something going south, but my overall observation is that with VCM more frequent OCI's may have been of benefit. I do the same 4500 OCI's on the 2011 Silverado 5.3 as well. Time will tell on all....
Another data point on this topic.
I have a 2008 Odyssey Touring with an almost identical experience to the user above.
OCI at around 6k miles with Mobil 1 Synthetic.
At 97k major service PCV had some carbon but still rattled.
Adjusted 10/12 Intake valves (all loose) and 2/12 Exhaust (tight).
Plugs were original and unremarkable.
Oil usage is consistent at 1/2-3/4 qt over the OCI since new.
Aside from the minor annoyance of the slight judder/vibration of the VCM kicking on and off so far so good.
The Honda settlement claims that the rings can "align" and cause oil consumption issues.
I can only assume this happens because of lack of combustion pressure when running deactivated. Not sure why this affects some and not others. Also not sure why there is a VIN range for the repair (not published) even though the settlement includes all year models listed.
Maybe an engine that uses VCM a lot early in its service life can get the rings shifted to a point where the gaps are aligned and they stay there for whatever reason.
The guys on Odyclub have figured out a way to totally deactivate VCM with no other side effects other than a CEL. This procedure is reversible but you would have to clear the CEL and drive for a while to pass most state inspections that use OBD2. That's one of the reasons I haven't disabled it yet.
I'm also unclear with what has changed to "correct" the problems with newer VCM engines. I know they have changed the VCM yet again (VCM3?) and gone back to a 3/6 mode with no 4 cylinder mode.
For the very small improvements claimed in mileage VCM certainly introduces more failure modes and obviously has some unintended problems regarding long term durability.
If we get another minivan I will look closely at the Toyota product. No VCM and no timing belt are certainly selling points in my book.
