Might have been mentioned here before, but I figured with the few Volvo folks we have, this would be handy.
Specifically the GFs 2002 S60 with 140k: The turn signal seems to work when it wants to and a bit of tweaking is needed to get it to even engage now. Over the last year, I have noticed it getting worse so it led mean to Google. The dealer said it was a bad wire connection and that the whole assembly needs replaced. I guess they had the faulty connection part right.
Found this. Seems like a simple DIY fix. HTH.
http://forums.swedespeed.com/showthread.php?62179-Solution-to-Intermittent-Turn-Signal-Problem
