When the weather is cold, I start to leak coolant. This has happens every so often because the lower hose on the radiator becomes loose. I tightened it a few weeks ago but am wondering if I should replace it or if it just needs to be ridiculously tight. This is the type of clamp where tightening the bolt will tighten the clamp. The clamp itself is thoroughly covered in coolant residue so I do not have an idea of the condition of the metal itself. I tighten it robustly but have been concerned that if I put all of my strength into it I will cut into the hose (??).
Should I replace? Make it extremely tight?
One more stupid question- If I replace it, the hose should stay on the radiator, correct? I would do this on a completely cold car, of course. Just do not want a surprise bath.
