Both the Mystik JT-6 and the Valvoline Synpower grease are NLGI GC-LB. just wondering is the red fine or do my fittings prefer grey Moly......
Fittings:
Outer tie rod
Inner tie rod
Upper ball joint
Lower ball joint
Idler arm
Pitman arm
Am I being over-zealous, that is, will I notice a ride/steering difference and prolonged component life OR never be able to tell a thing.
Honestly, now that I have both I will just pick a preference then use the other one after the first is used up.
Fittings:
Outer tie rod
Inner tie rod
Upper ball joint
Lower ball joint
Idler arm
Pitman arm
