What I have is a Polaris 250 two stroke. They don't have reed valves and are pretty much stupid simple engines. I have rebuilt over 20 without incident, till this SOB. So I rebuilt the top end, I put a New Wiseco piston in it with a bored out .50 over. Everything went together nicely. It would not start, with starter fluid, no go. Swapped out carbs, no go. Tore the flywheel off, keyway is fine, changed the cdi out, put a new coil on, spark is nice and blue, still no start. Soooo, I bought a compression gauge and I only have 80 psi of cylinder pressure. Polaris calls for 110 to 130 on that model. So I tore it down and found nothing wrong. I put it together with a stock bore and another New Wiseco piston. Torqued all the nuts and bolts to factory specs. Checked and only had 80 psi. So I tore it back down AGAIN. I changed the head and head gasket. (I got a lot of Polaris parts on stock). I added oil to the cylinder and got it to 95 psi. So I thought I will try to start it and I got it to start. It would rev up and I kept it running for about a half hour. I adjusted the air screw on the carb, set the idle, idled fine no loping, no erratical behavior, fine. Shut it off, wont start. I hit the button, starts for a second and dies and wont start. Let it sit overnight and go out hit the button, fires right off for a second and dies, wont start again, even with starting fluid. I was going to change the crank seals and even threw a set in the freezer, but that's a waste of time, it idles too nice, if they were out, it would do all kind of crazy stuff and that doesn't effect the compression anyway. My next guess is I will swap out the exhaust, I think it could be plugged up. Guess after that is I may disconnect the rev limiter, I ve seen them do some weird stuff on Polaris. If that doesn't work, I will be taking it down again and this time checking the cylinder base surface on the block for planeness. I am at a loss and if I didn't have so much time in this thing already, I d probably just part it out. I am at wits end. I have extra motors, but what could be the issue? I hate to swap motors out at this point, but I am not happy and spent way too much time on this. Any Thoughts? or Ideas?
