Hi Folks!!
I just joined the forum and have a question about upper cylinder lubrication?? I have a 2004 Mercury Marauder I SuperCharged in 2005 and it had 256K miles on the original engine when I lost the top ring land on #7 piston (we think detonation?) under 9 PSI of boost......it ran right BAD!!
I have used about 1/2 oz per gallon of TCW-3 oil in my fuel since the first fill up.....NOW I am being told ANY oil in fuel will promote DETONATION?? Is this true?? I was told different by an old "Oil Guy" 25 years ago when I started this practice in all my 4 Cycle engines with GOOD RESULTS......I thought??
Help me out here since the rebuild is expensive and I don't wanna repeat this IF oil caused it!!
Thanks in advance!!
Thanks in advance!!
