Hi
Penrite are about to release their version of the 0W-16 see product data below.
For your info. I will not be using it.
The timing of release not mentioned.
The PDF states it is proposed to be used in vehicles designed for this viscosity only.
http://www.penriteoil.com.au/pis_pdfs/ENVIRO+HYBRID 0W-16 JANUARY 2015.pdf
ENVIRO+ HYBRID 0W-16 can be used where fuel economy oils are specified such as in Toyota Prius, Honda Civic and Lexus ES3000h.
ENVIRO+ HYBRID 0W-16 is NOT for use in vehicles not specifically designed to run on SAE 0W-16 engine oils. It cannot be used in diesel engined vehicles or in motorcycles.
Industry Specifications
API SN
Typical Data
Density at 15oC, kg/L 0.848
Viscosity, Kinematic, cSt
at 40oC 39
at 100oC 7.6
Viscosity Index 168
HT/HS Viscosity at 150oC 2.45
Cold Cranking Viscosity, cP -35 oC 4367
Zinc, Mass % 0.094
Phosphorus, Mass % 0.077
Sulphated Ash, mass % 0.9
Base Number 7.9
API SN
Typical Data
at 40oC 39
at 100oC 7.6
Viscosity Index 168
Zinc, Mass % 0.094
Base Number 7.9
